Ironhead A place to talk about Ironheads.
Timing Case Leak
Old Sep 12, 2008 | 05:53 PM
VikingRider's Avatar
VikingRider
Default Timing Case Leak
Re-installed the timing case cover on my '76 xlh.
My timing case leaks because the new gasket I put on doesn't have a portion that surounds the case passage hole shown in the picture. (the arrow points to it, and it is directly below the oil return strainer)
HD must have a couple variations on that gasket, because I ordered 2, (same part number)and they are both different. Obviously the one I used doesn't cover that passage....now I got a leaker.
What does this passage in my case do?
Thanks
Old Sep 12, 2008 | 07:14 PM
Grog's Avatar
Grog
Leak!?!
Old Sep 12, 2008 | 08:09 PM
piniongear's Avatar
piniongear
Thanks
This is not an oil passage. What you point to with the arrow is the hole where the retaining pin for the oil strainer and gasket resides.
This pin is inserted at the factory and then peened (the slash mark) to prevent the pin from coming out.
Now, although it is not a passage, it will most certainly pass a small amount of oil, so you need a timing cover gasket that covers this up.
As to the difference in gaskets, I can only say they must be for different year models..............pg
Old Sep 13, 2008 | 01:07 PM
VikingRider
Be warned....not all HD gaskets have the tab that covers this retaining pin hole, eventhough the part number is the same!
I should have caught it, but I didn't. Now I'm pissed!
Old Sep 13, 2008 | 03:49 PM
pyro's Avatar
pyro
Now I'm pissed!
Why? everyone here has asked themselves, at one point, "WTF was I thinking?". Happens to me more than I care to admit. But, unless you didn't catch it untill some type of major mechanical malfunction directly linked to the issue, take it on the chin and feel good about bringing something to the forum that may help someone else. One man's f-up is another man's preventitive maintanance.
Rich
armydad1
Oil Archive (no new posts)
Nov 5, 2012 03:42 PM
stevenlisa
Ironhead
Apr 26, 2011 10:27 PM
sportster dave
Ironhead
Oct 13, 2009 06:47 PM
davisrf
Apr 23, 2009 09:44 PM
dirty78ironhead
Ironhead
Nov 8, 2008 11:12 PM
