General questions
My son gave me custody of his 80 Sportster while he's deployed overseas.
I don't know **** about bikes but very mechanically inclined. I just did a total rewire on the bike. There was so much **** Gerry-Rigged, it's a wonder it ran. It was hard to start when I got it. Anyway, the rewire went well. It starts right up and runs great.
I just have some questions so I know what I have.
Ironhead right? Is it 1000cc or 1200?
The exhaust has a pipe connecting the two mufflers. I was told that I should keep it. My problem with that is the tach cable runs straight up between the mufflers and across the joining pipe and has melted the outer sheath of the tach cable. Someone suggested to relocate the tach cable. Not sure what they mean by relocating it. I thought about a heat shield over the pipe. It's roughly 1 inch OD. Do they make heat shields for pipes that small? will that protect the tach cable? My other option was to install a digital tach/speedo. I saw there was a digital converter for those, and can I install that piece down where the tach comes out of the engine case. If so, I can just route the wires away from the pipe and up to the digital tach/speedo unit. I have one but unfortunately it's not a "Digital Dakota". It's in a box with other ****(misc. parts) my son got with the bike and has no wire schematics.
Anyway, your help and advice, as always, is much appreciated!
Nick
An option is to get an electronic tach part number 92051-81A. This tach was used from 1981 to 1983. It looks identical to the mechanical tach but no cable, so you maintain the original look of the bike. It connects electrically to any electronic ignition; i believe also it can be connected directly to the ignition coil. I hooked it up to a Crane Hi-4 on my 1980; i have one also on my 1978 hooked up to an Ultima ignition.
Here's one on eBay [always search using the part number] ...
http://www.ebay.com/itm/NOS-OEM-HARL...1a895a&vxp=mtr
Here's the Ultima ...
http://www.ultimaproducts.com/programmableignition.html
