Brought the mpg back to normal
  #71
Old 02-25-2017, 05:39 PM
Steve Cole's Avatar
Steve Cole
Steve Cole is offline
HD EFI Guru
Received 3,446 Likes on 1,585 Posts
Originally Posted by SWMB
My M8 Road King in the 1st 1000 miles hasn't strayed to far off 40. It always amazes me when these MPG posts come up how different riders mileage vary's. I could understand 10% but lots of times we're talking 25% or more.
Just ran 200+ miles on my '17 RK. I filled the tank to the top and headed out. Mostly Hwy with speeds in the 70 - 80 range most of the time. About half way out stopped and talked with a friend and then returned. Return to same station and refilled from the same pump. First fill was about 4 hours before last fill and in that time they raised the cost of fuel 10 cents a gallon! 42.94 mpg hand calculated
  #72
Old 02-25-2017, 06:07 PM
rjjj629's Avatar
rjjj629
rjjj629 is offline
I've got 2100 miles on my SGS and I've been doing the hand calculation thing on most of my fill ups. Been getting 44 mpg +/- 2 pretty consistently.
Like a previous poster said, for a while I've been kinda amazed at the different mpg values people seem to be getting. The more I keep thinking about it though just about anything in the 35 to 55 range is kinda believable to me. There's a lot of variables.
  #73
Old 02-25-2017, 07:33 PM
Yzzyx's Avatar
Yzzyx
Yzzyx is offline
Here are 131 tanks, meticulously hand calculated, for my previous '16 RGS.
46.2 MPG overall.
http://www.fuelly.com/motorcycle/har...6/xyzzy/407807
The M8 is much more efficient than the TC. Plus my riding style, over time, has refined. Note how the trend, over time, is upward:
http://www.fuelly.com/motorcycle/har...7807/fuelchart
I got tired of doing all of the hand calculating and since the onboard computer matched my results so closely, I just trust the computer now.
When I ride with others, I never need to stop for gas before they do. And I always put less gas in. Always.
I've gotten more than 300 miles on a tank countless times.
When I do my 1,000 mile rides, I expect to spend $50 on fuel and that is what happens.
YMMV... literally.
  #74
Old 02-25-2017, 07:35 PM
lh4x4's Avatar
lh4x4
lh4x4 is offline
bwoltz: When you fill up and the DTE says 300 miles until empty that is telling you that the EMC was at an average of 50 mpg. It can go down or up after filling depending on how it is riden.
The DTE is always calculating based on the average in the EMC. That is the assumption it makes when you fill it and as you ride it constantly adapts to current averages.
  #75
Old 03-03-2017, 07:38 PM
Ovaltine Jenkins's Avatar
Ovaltine Jenkins
Ovaltine Jenkins is offline
Three approximately 150-mile legs of a recent journey I may or may not have taken on a 2017 RGS with definitely-not-aerodynamic soft lowers.
38.4 MPG - 80 MPH avg, ~78 degrees OAT, vents open
35.1 MPG - 88 MPH avg, ~78 degrees OAT, vents open
36.0 MPG - 80 MPH avg, ~52 degrees OAT, lower vents closed
Max Headflow (03-03-2017)
  #76
Old 03-04-2017, 10:09 AM
FLTRI17's Avatar
FLTRI17
FLTRI17 is offline
This parallels my findings with my RGS.
Bov
  #77
Old 03-04-2017, 10:35 AM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Yesterday got to take the '17 RG out for a little 300 mile ride. Weather was in the upper 70's and each time I came up to a stop the oil cooler fan was on and the engine EITMS came on. Mind you this happen just as I came off the interstate and I had been traveling between 70 - 75 mph for about an hour straight. I used the cruise control to try and keep me from running my normal hwy of 80 +! Traveled down a back road through the mountains that had a speed limit of 55 mph and when you came into a town it dropped 35 - 40 mph. That road was 44 miles long and I travel through three towns along the way. Each and every time I slowed into a town if I missed a traffic light both the EITMS and oil cooler fan were on when I stopped.
So what does this mean, I do not know, but sure glad I added the oil cooler with fan because come summer time and the heat goes back up to its normal 80 - 100 degree IMHO your going to need it from what I saw today.
My route was I-5 north from LA to 99 north to Bakersfield. Turned around in Bakersfield and took 99 back to 5 and got off at Hwy 126 west. That's an old Hwy that runs through the mountains over to the coast. Took Hwy 1 back down the coast to LA. Today the weather is dropping to a high of low 60's with rain coming tonight, glad I was able to sneak in a little winter relief. Got 42.1 mpg this time hand calculated
  #78
Old 03-06-2017, 11:48 AM
Wmitz's Avatar
Wmitz
Wmitz is offline
Steve, thanks for the insight. My question is how is your bike tuned, meaning are you running the mid .980's lambda like tts maps and do you still have a header with the cat in it? Thanks
  #79
Old 03-06-2017, 02:14 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Yes, my bike has the stock headpipe with cat in place. I have the 4.5" Street Cannon mufflers,SE High Flow Air Cleaner and TTS 100-M8 camshaft in when this testing was run. If your looking for the tune, its in the current Mastertune2 product, so you can review all of it there.
  #80
Old 03-06-2017, 05:14 PM
Barleysoda's Avatar
Barleysoda
Barleysoda is offline
Stage III
Originally Posted by Heloguy
Yeah, I'm having a hard time believing it also. I am barely getting 37mpg.
I couldnt believe it either. I have about 1400 on my 17 SGS and I am getting around 33/34. I do seem to lay on the throttle a bit though.
Mchad
10-23-2018 12:29 PM
pauletich
08-05-2010 10:18 AM
Sancho
01-17-2010 08:42 PM
wnogood
11-22-2007 08:33 PM
NCCopBikeRider
09-19-2007 11:59 AM
Quick Reply: Brought the mpg back to normal
