Ventilator AC 117 Badging
Old Aug 27, 2017 | 10:10 AM
Heatwave's Avatar
Heatwave
Member
Default Ventilator AC 117 Badging
I noticed on the 2018 CVOs the Ventilator AC now comes with a "117ci" badge. Anyone have access to a part number for the badge? I might want to add to my 2017 CVO with Stage 4 kit (117).
Old Aug 27, 2017 | 10:23 AM
dixonk's Avatar
dixonk
My question for changing the 17 CVO to a 117 is how does one change the badges on the heads? Are the 117 badges available for that as well?
Old Aug 27, 2017 | 10:34 AM
mjwebb's Avatar
mjwebb
I looked at the 18 CVOs yesterday, really want one but way too much money..think I'll just add the AC 117 cover insert..they say if you repeatedly tell yourself something is true you end up believing it..it's my only chance of ever 'having' a 117 CVO anyway
Old Aug 27, 2017 | 10:48 AM
Heatwave's Avatar
Heatwave
Member
I went with the CNC Ported Heads in the stage 4 kit on my 2017 CVO Limited. The heads have "Screaming Eagle" on rear and "CNC Ported" on front . No displacement.
Old Aug 27, 2017 | 11:55 AM
dixonk's Avatar
dixonk
Good to know. I guess if you go stage 3 you will have to live with the 114 badges. And the primary cover.
Old Aug 27, 2017 | 12:20 PM
Heatwave's Avatar
Heatwave
Member
I switched my primary cover from the factory plain 114 to this one from Customer Engraving
Old Aug 27, 2017 | 12:23 PM
Macrunner's Avatar
Macrunner
I think it's Harley part number 14101009. Found it by pulling up a 2018 M8 117 on SIP and going to the air cleaner section on the parts identifier.
Old Aug 27, 2017 | 01:00 PM
dixonk's Avatar
dixonk
Or you can get the 2018 primary cover
Old Aug 27, 2017 | 01:01 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
There are both 117 and 114 badges on the 2018's, so for those of you using a ventilator filter assembly you should be able to order either one if you like. The CVO is the 117 version and the 114 comes from the new Softail. Same goes for the primary covers except the 114 primary cover will not fit on the Touring primary.
Old Aug 27, 2017 | 01:07 PM
Heatwave's Avatar
Heatwave
Member
The 2018 117 is rather plain. No reference to Custom Vehicle Operation like the custom Engraving Derby.
