I would imagine you can. I suspect that you'd need to pick the passage that feeds the filter.. In that case none of these parts will work. I suspect that the line is too short and the passage hole to be 1/4 pipe.
I check oil flow in M8 service Manuel-there is actually 2 plugs! 1 looks to be in the channel going to filter and the second plug looks to be in (clean oil) passage to crankshaft! The access to inlet plug is easy, but to access other plug would require removing front cyl exhaust pipe! I am looking into this option-will keep you posted!
i check oil flow in m8 service manuel-there is actually 2 plugs! 1 looks to be in the channel going to filter and the second plug looks to be in (clean oil) passage to crankshaft! The access to inlet plug is easy, but to access other plug would require removing front cyl exhaust pipe! I am looking into this option-will keep you posted!
i just did this to mine using an fittings my o2 sensor is very close to the fitting and i mean very close
