You know they said the same negitive stuff when the 88,96,103 came out.
And yet the bikes are still on the road and bikers aren't stranded on every corner . Hell I had a 2008 Streetglide the TBW would just die Turning left, Right, Taking off. I called that bike the pucker,or ****** Pucker if I was pissed.
Bottom line is just ride and do your safety checks and enjoy.
Or can anyone chime in and point me out where in the manual I can find how to check sumping?
Not experiencing any issues so far (knock on wood), but I am curious.
Since the sensor is NOT in the lowest portion of the sump you will never get all the oil from the sump. That being said there is a reason they call it a “dry sump system”. Believe it or not, ideally there isn’t supposed to be oil left in the bottom of the sump. A little residue (1-3oz) shouldn't cause drag on the flywheels but more than 3oz as measured from the sensor plug, may be causing drag, how much I don’t know.
Bob
highly doubt it, that spec was a result of new unexpected problems and subsequent SB1450 announcement..if your engine behaves great and unchanged since day one 'fugget aboudit' and don't lose sleep over it..if a 'serious' issue manifests itself it'll be obvious
