Oil Archive (no new posts) An archive of oil related questions and comments.
drain plug help!
Old Jul 25, 2006 | 03:42 PM
rkc's Avatar
rkc
5th Gear
Default drain plug help!
need a little help guys as stupid as this sounds this will be my third fluid change on my bike ,
i have an 05 road king custom on the front facing side of the oil pan i pulled out the oil drain plug as usual but i also took out the plug rite next to it thinking it was the trans plug! in the manual it says do not remove !! did i mess up??
Old Jul 25, 2006 | 04:05 PM
sleepneagle's Avatar
sleepneagle
Default RE: drain plug help!
the forward facing recessed plug next to the oil drain does go into the pan. This is where you would install a sensor for oil temp gauge. The far right side plug is the trans drain. Jiff side plug is oil. Naw you didn't mess up, reinstall and torq, you'll be ok.
Old Jul 25, 2006 | 04:25 PM
rkc's Avatar
rkc
5th Gear
thanks for the reply sleepneagle! just one more reason why i like this board! lot of good folks !!
Old Jul 25, 2006 | 05:39 PM
dawg's Avatar
dawg
Like stated it is for oil temp sensor. Now that you removed it you might as well install an $80 oil temp guage
Old Jul 28, 2006 | 05:35 PM
fatboymike's Avatar
fatboymike
DO what the dawg says and buy the oil temp gauge.[sm=biker.gif]
PhatBoyHigh
Nov 25, 2015 11:11 AM
FireFighter200
2014-2024 Touring Models
Mar 5, 2015 05:55 AM
HDSAE60
Aug 12, 2009 08:58 PM
dchoran
Aug 12, 2007 02:48 AM
bob53
Mar 19, 2007 09:25 PM
