M8 sump check
Old Feb 28, 2018 | 09:27 PM
berniemc's Avatar
berniemc
Default M8 sump check
Took the plug out of oil pan on my M8 today to check on how much oil was in it as I have done on my Vtwin and it drained all the oil from the motor.Can anyone explain this to me?
Old Feb 28, 2018 | 09:35 PM
Toner123's Avatar
Toner123
What plug? Your suppose to remove the crank shaft position sensor.
If more then 6 oz your sumping
Old Feb 28, 2018 | 09:37 PM
berniemc's Avatar
berniemc
My bad...I removed the 3/8 hex plug that your not supposed to remove.
Old Feb 28, 2018 | 09:39 PM
Toner123's Avatar
Toner123
Haha. It's all good, it happens. You should be able to still remove the crank shaft position sensor and measure how much comes out
Old Feb 28, 2018 | 09:41 PM
berniemc's Avatar
berniemc
Thanks.Will do that tomorrow.Changed my oil a little early!
Old Mar 1, 2018 | 01:25 AM
badcooky's Avatar
badcooky
Bernie, Bernie, Bernie what are we going to do with you mate ?
Cheers man.
Old Mar 1, 2018 | 04:56 AM
tbob's Avatar
tbob
You just can't make this stuff up folks,Why would you and hope you don't crack the casting putting it back in. It's probably gonna leak now,Good luck .
Old Mar 1, 2018 | 07:21 AM
berniemc's Avatar
berniemc
Probably not get a job as mechanic with Harley.It wont leak and I didnt crack case.Have took that plug out of my vtwins for years with no problems.
Old Mar 1, 2018 | 09:50 AM
SWThomas's Avatar
SWThomas
Sometimes searching for issues that you don't have can induce other issues. Better to leave well enough alone unless you have a problem.
Old Mar 1, 2018 | 12:17 PM
berniemc's Avatar
berniemc
I finally drained the right place and got 4 ozs so that aint bad for 3600 miles I guess.
