Arlen Ness inverted
Old 03-16-2018, 01:30 PM
Quik's Avatar
Quik
Quik is offline
Received 2,572 Likes on 1,524 Posts
Default Arlen Ness inverted
Any of you guys running the Arlen Ness inverted air cleaner? If so, what are your thoughts. Synthetic filter material, never needs oil or a rain sock, just clean it let it dry and reuse or so the guy at Arlen Ness says. I think I will replace my HD high flow with this just wanted to see if any of you guys are or have ran it.
Old 03-16-2018, 05:50 PM
Alexspain's Avatar
Alexspain
Alexspain is offline
And not necessary us sock for rain? Is it hi flow air cleaner ?
Old 03-17-2018, 07:50 PM
Quik's Avatar
Quik
Quik is offline
It's an open AC with a synthetic filter, has a wire mesh over the filter element. I'm really leaning towards it mainly to match my Ness boards, shift/brake pedals and grips. Not sure if it will flow better than my HD high flow or not.
Old 09-16-2018, 12:19 PM
pdave's Avatar
pdave
pdave is offline
Anybody running one of these. How do they compare to the Big Sucker as far as performance?
Old 09-16-2018, 12:34 PM
Quik's Avatar
Quik
Quik is offline
I ended up going with this Arlen Ness, it does not have the synthetic filter like the inverted series but I liked the look better. Performs fine but I do get a little more noise out of it compared with the SE high flow.
Old 09-16-2018, 03:43 PM
Keithhu's Avatar
Keithhu
Keithhu is offline
Received 5,364 Likes on 2,619 Posts
Never needed a rain sock, have ridden through some biblical rain.
Old 09-16-2018, 03:47 PM
Quik's Avatar
Quik
Quik is offline
You running the Ness inverted with synthetic filter?
Old 09-16-2018, 04:55 PM
Keithhu's Avatar
Keithhu
Keithhu is offline
Not now, but I've run nearly identical PM round open ACs on several past bikes, no issues in the rain.
Old 09-16-2018, 05:24 PM
pdave's Avatar
pdave
pdave is offline
I like the looks of this one too. This winter I'm going to be the RS 468 cam and Fullsac 2" cores. Someone (Stonecold?) posted a dyno chart using this combo with the Arlen Ness Big Sucker. I prefer the looks of the inverted and was wondering if the performance was similiar.
Old 09-17-2018, 08:44 AM
hollandhunter's Avatar
hollandhunter
hollandhunter is offline
I dont know much about it but it sure looks good in the pic above!
Quick Reply: Arlen Ness inverted
