Hey Steve. Is there an advance cam sprocket by Andrews for the M8 like the twin cam. My old bike had the S&S 585 cam with advance so I can get the torque earlier.
The sprocket that Andrews makes fits on the crankshaft that allows the cam timing to be advanced or retarded depending on which way you install it. The TwinCam and M8 both use the exact same OEM gear on the crankshaft, so using the Andrews gear will work for the M8.
really this is good to know been wound wrong about that thanks for the information
