Clutch recall....now includes brake fluid flush?
You are getting some bad information on the brake flush being part of the recall . Please read it. I have had the clutch recall done for some time now. I was having no issues before nor any after. The brakes had just been done in Oct anyway when the sidecar was mounted anyway.
You (and others) may very well be correct. On the other hand, dealer told me the clutch recall bulletin "was recently updated to include that all dot4 fluids are to be flushed". I was simply reaching out to see if others had heard anything similar. Appears no one has. Bike is stored at the dealer and be worked on soon. Will happily post service order when complete and attempt to get additional details.
Just left the dealer. Bike is in for clutch recall and I planned to have other things done. Told service adviser I wanted a 2 year brake fluid flush as well. She tells me that it is part of the recall. I attempt to correct her saying I know the dot4 flush is part of the clutch recall, I am referring to the brake fluid. She understands what I am saying and says that the recall now includes flushing ALL dot4 fluids. Not dumb enough to debate a free brake fluid flush but I follow the forum fairly closely and don't recall this amendment to the recall ever coming up. Has anyone heard of this?
Doesn't say your brakes were actually bled.
Both the SA and tech looked me in the eyes and said brake flush was done as part of the clutch recall process. Note the 2 different recall #'s used on the service order; Google them. So your theory is, I asked for the two year brake fluid flush to be performed and instead of charging me, the dealer fraudulently claimed they would do it for free and actually never did it? By extension of that logic, the dealer has too much money and does not want to charge for new business. Clearly, they were lying and this is some Canadian MoCo conspiracy. thanks...I'll pass this on to Robert Mueller.
The following 2 users liked this post by canuck_flhtk:
mazz (03-16-2019),
roadkinglobo (04-12-2019)
Exactly..that's why I'm baffled. The question is, did they eff up in applying this recall to a 2017? From what i am hearing is that the answer is probably yes. Had latest oil pump back plate installed and clutch springs installed as well while in storage. Attached invoice is far less than what i expected. probably should run out and buy a lottery ticket.
