SE adjustable pushrods and loctite?
I just finished up an install of the SE 462 horsepower cam and SE adjustable pushrods. I payed careful attention to the factory service manual and to the directions included with the pushrods, but nowhere does it mention using any sort of threadlock on the pushrod's jam nuts. I've only installed one other set of adjustable pushrods before, and they were the Fuel Moto adjustable's and they did call for red loctite.
So, am I OK without loctite on the jam nuts?
NoSecCatfish (03-18-2019)
Cut them
Some people have said if they come loose eat to fix. Rolling back to find tdc to set lash, doesn't seem easy alone.
BUT, common sense use of loctite is certainly never a bad thing. Just a super small dab of high temp should suffice, and not make it miserable when you go back for a new cam install.
