Matching bikes, one hot, one not
I must be a glutton for punishment because I have no complaints about my engine's heat. I've ridden a 1980 FXE Shovel 74", a '99 Softail Custom with the last model year Evo, a 2000 model RoadKing with a first gen 88" TC, an '09 Street Glide with a 96"TC, and now my 2020 Roadglide Limited 114" M8. All of them make a lot of heat and all of them are awesome. I love my M8 and I don't worry about the heat unless and until I need to. If you want comfort, drive your car/truck.
I wish my bike didn't exceed 225 degrees! I know the circumstances are different, but I just came back from a short ride on the highway where I saw my power vision hit 360 degrees (91 degree ambient temp). I took an IR temperature gun to the front and rear heads and they were between 314 and 322 degrees. I'm curious what others with oil cooled big bore engines are seeing for engine temps.
you're all best off without gauges..wife and I have logged 85,000 miles on oil cooled M8s under damn near every condition Mother Nature has to offer...don't know how hot the engine temps or oil temps ever got, but the bikes never seemed to mind and we never used synthetic fluids for anything...until now with her 2020 CVO uses SYN 3 and 5000 miles...less worry and fussing and more riding is what I say
The following 9 users liked this post by mjwebb:
AliensilverFXDBI (08-14-2020),
bradsULtd (07-12-2020),
Erilflynn (08-14-2020),
FattyMcJ (07-13-2020),
goblue90 (07-12-2020),
and 4 others liked this post.
Just reading through this thread, we are talking about a difference of 8 degrees in temp, lots of room for error with very little deviation in my opinion between two bikes. Although your bike may be the same model and color (irrelevant)...there is no factual basis to run a side by side test here. You are running different oil, different Motors (yes, they are the same size but still different motors unless you are swapping the same motor between bikes-joking of course), different riders who do not ride the same or use throttle the same exact way and potentially different tunes between bikes, different wear and tear....and numerous other factors.
Just as two different bikes do not make the same hp and tq values on a Dyno even if all parameters are exactly the same. This is all normal and expected. In my opinion it's normal to not have the same exact parameters between two bikes. Ok, if one bike was boiling hot and had a 20% variation in temp, then sure, I'd say there is something wrong. But 8 degrees....thats like 3% variance, I highly doubt your dealer is going to say you have an issue, but who knows.
The fans on my 2014 Ultra Limited almost NEVER ran. My 2020 RGL fans run all the time. I consider that a feature, not a bug. I just reached 10k miles and have not had it three months. This is the best Harley I have ever owned.
The following 2 users liked this post by Down South:
jeb42 (08-12-2020),
Max Headflow (08-13-2020)
The following 2 users liked this post by Dutchy3051:
mjwebb (08-13-2020)
Thermostat could be opening at different times as said earlier.
Tune could absolutely make that little of a difference but the chance of two factory tunes being different is unlikely but definitely possible, especially if they had a few months difference in mfg dates and the factory tuner modified the stock tune for some reason or another.
The bottom line is, if it's new ride it hard and ride it often. If you break it, take it back and let warranty fix it.
If it starts and goes and isn't low on coolant or oil ride the **** out of it.
dkrispin
08-17-2020 04:06 PM
