Compensator Spring
Old May 12, 2025 | 11:54 AM
jake24lt's Avatar
jake24lt
https://www.sscycle.com/products/hea...for-m8-models/
Old May 12, 2025 | 03:02 PM
propflux01's Avatar
propflux01
So… I take it no one has used the spring?
Old May 13, 2025 | 03:58 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
We've used a handful of solutions for spring packs to tighten up Twin Cam & M8 compensators over the years including the Evo Industries and Feuling spring kits, they work well and help eliminate excessive play while still allowing the compensator to do its job. We typically disassemble and service a handful of primaries every day here, the ramp wear we see firsthand is not limited to just Cycle Rama ramps,we commonly see it on others as well. In most cases this wear does not affect the operation and I've never seen an aftermarket ramp fracture. There are a lot of variables that play into that including but not limited to the specific primary lubricant, the surface condition on the spokes the ramp mates to, the engine combination, how the bike is ridden, and also the spring pack being discussed here.
As for the Baker Compensator, we really like them as well and have installed many, many of them. I run one in my personal Road Glide that makes just under 170Hp and it's worked flawless. When doing research note there have been several generations of Baker comps, however the M8 units were completely redesigned from earlier versions (Twin Cam was updated as well). I don't believe we've ever seen an issue or warranty on a M8 Baker unit.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old May 13, 2025 | 04:26 PM
Old New Rider's Avatar
Old New Rider
@fuelmoto
So it's ok if the surface of a compensator ramp smears?
I'm guessing using a heavier primary oil will help slow this down. I'm going to change from various primary oils (including Formula+ 20W-50 engine oil) to the newer 80W-140 Heavy Synthetic Gear Oil. I changed to this in my transmission for similar reasons (high load, high heat) and it performs much better - shifts better, finds neutral better.
If the latest Baker harmonic balancer works for high hp builds, why is anyone still using ramps & clutches? I would like to know because I installed the Cycle Rama compensator ramp.
Old May 13, 2025 | 05:05 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Originally Posted by Old New Rider
@fuelmoto
Because the ramp runs metal to metal there is going to be some smearing/galling, some of this is pretty normal however there is no blanket statement.
I feel there is really a few things going on in the primary related to lubrication, there are difference components with different requirements lube wise. For example the comp ramp needs lubricant with sheer strength to help protect surface galling as the comp runs metal to metal. On the other hand the clutch needs lube that will allow for proper clutch pack engagement, clutch specific lube typically lacks friction modifiers that are found in other general engine lubes. Because the primary shares components there is some compromise for which lubricant works best.
Its really price that drives the option of replacing the comp ramp vs replacing the entire assembly. The ramps start at about $439 where the Baker compensator runs $599.00.
Old May 13, 2025 | 05:32 PM
NZLowrider's Avatar
NZLowrider
So do you guys at FM still recommend the Belray for the primary for a cammed M8?
Old May 13, 2025 | 08:40 PM
ntraindavefl's Avatar
ntraindavefl
Originally Posted by Bigt001
I got screwed buying an early release Cycle Rama ramp that wasn’t properly surfaced hardened. I bought it directly from them but they wouldn’t even give any kind of a discount on a new one. Screw them!
Not a surprise. Arrogant as F over there
Old May 13, 2025 | 09:16 PM
klammer76's Avatar
klammer76
Originally Posted by MattLS6
Does anyone know when Cycle-Rama released their compensator ramp? When I last had my primary cover off I too noticed wear, just not as bad as pictured. Wes assured me it was ok, but I’m skeptical. Will continue to monitor.
They assured me mine is ok also. I'm skeptical too, not using it again. Just can't bring myself to use their ramp again. I'll go with a different supplier.
Old May 14, 2025 | 05:24 AM
propflux01's Avatar
propflux01
Since you do see a lot of bikes roll through there, how many actually come in with fractured ramps? All I have is a mild cam (22x), and I am a temperate rider. Mostly hilly 2-lane and a few 80MPH Slab runs, with the occasional "Italian Tune-up". Seems to me if one buys one of the ramp, it would already be closing in on "baker" territory as far as price goes.
Old May 14, 2025 | 05:25 AM
propflux01's Avatar
propflux01
What's yours look like?
