Compensator Spring
Old Oct 27, 2025 | 04:15 AM
  #41
lp's Avatar
lp
Originally Posted by lp
Thanks for your feedback. I have one right here on the desk next to me - just waiting for the opportunity to install it... sounds promising!
Originally Posted by Steve Cole
People need to understand that smearing of the metal on the ramp is NOT OK, period.It's no different than a roller bearing smearing. If the metal is moving its time to replace it as all it's going to do, is get worse. The metal that's coming off is going to be moved around in the primary by the oil tearing other parts up. Funny thing is the guy who developed and started making these replacement ramps (TTS) over in England for his high powered supercharger kit bikes has never had a failure, yet all the various copies have.
Good info Steve. I was talking about the spring. Amazingly enough at 80K my OEM comp looks near new - just have a little shutdown rattle etc. Hopefully it tightens up the pack a little.
Old Oct 27, 2025 | 09:15 AM
  #42
Max Headflow's Avatar
Max Headflow
Originally Posted by Old New Rider
@Max Headflow
Max, I think the issue here is what is reliable today for M8 power uprate builds. A bunch of us bought Cycle Rama not knowing quality history. So, I don't think we'd be shopping for discontinued models parts, would we?
TC cam and spoke/sprocket parts don't fit the M8. Not sure what you are trying to say..
Old Oct 27, 2025 | 09:44 AM
  #43
Old New Rider's Avatar
Old New Rider
OP has an M8 and asked about spring pack upgrade to lessen comp thrashing. Your reply to Steve Cole discussed the older engine models, not relevant to this discussion. Steve was saying you don't need more spring load when a quality comp ramp is used, his experience was with TTS comp ramp for power upgrades.
Old Oct 27, 2025 | 09:53 AM
  #44
Max Headflow
If you look at the sentence before my highlight, Steve was clearly talking about evolution of design.
Old Oct 27, 2025 | 12:46 PM
  #45
Old New Rider
But the point of the posts are what works today.
Old Oct 27, 2025 | 01:28 PM
  #46
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Everyone also needs to remember that HD themselves came out with a shim kit for the compensator as they found there loose tolerances were biting them in the *** again. You may want to look at the instructions they give with the shim kit and make sure things measure properly while you in checking and/or adding a spring to tighten them up. We have been adding an extra stock spring on the end to tighten them up with great success, but only do it as necessary. No need to put more pressure on it that's not needed in all cases.
Old Oct 28, 2025 | 12:32 PM
  #47
Old New Rider
Ok, but HD compensator ramp is junk too - a raw casting in a cyclic, high stress application. Members have shown these destroyed, idk if stock or only power uprates.
I guess the point is if a quality compensator ramp is substituted (TSS only?), the original spring pack is adequate.
Would be nice if somebody just got to the point of what an adequate design is for uprates instead of debating the past.
Old Oct 28, 2025 | 03:40 PM
  #48
Steve Cole's Avatar
Steve Cole
HD EFI Guru
I'm an Old Dog (70) so when I find something that works well, I stop looking. If you keep adding pressure to the spring pac the next part in line is going to start failing, and those are the Stock spokes it rubs on. This is why I do not want to add any pressure if not necessary.
Old Oct 28, 2025 | 04:20 PM
  #49
Max Headflow
There is nothing wrong with the raw casting buy being cast. It's more of a design issue with how thin they made the trough on the cam.. I've not seen a TC cam break and it's the same material. Even on pumped up motors.
Going to a stronger non-cast one cure.
Old Oct 29, 2025 | 12:15 PM
  #50
Old New Rider
Yes, there is - in a tensile fatigue application. Wanna get into the S-N curves for materials?
