Tamarack Lowering Kit for Rushmore tourers
Old Mar 7, 2016 | 06:29 PM
W€€DWacker's Avatar
W€€DWacker
Default Tamarack Lowering Kit for Rushmore tourers
Hi all. Fairly new to the forums here, mostly reading. Lots of good information being shared here. Very cool bunch of people here.
I purchased a 14 Ultra Limited last fall. I'm 5'7" and need to get a bit lower to achieve comfortable flat footedness.
Im already in process of sending my seat to mean city but I'm also looking at lowering kits.
Does anyone have any experiences with this lowering kit. I've done a lot of research and a lot a these kits are questionable due to shock rubbing issues because of the wider side bags on the Rushmore touring models. I noticed with this kit in second pic there are bag spacers that permanently mount to the bags. Any experience or opinions of this kit? Thanks.
http://m.ebay.com.au/itm/DESIGNED-FO...-/291686876640
Old Mar 7, 2016 | 07:36 PM
wmprof's Avatar
wmprof
I've used the LA Choppers lowering blocks for both air shock and premium adjustable shock street glides. The LA Choppers blocks keep the stock geometry.
Both bikes needed some customizing of spacers and washers to fit free of saddlebag interference. Not supposed to work with premium adjustables, but I just mounted the adjustable shock upside down. Problem solved.
Had a local upholsterer modify stock seat for less than $100, and have HD CVO style solo seat which sits a bit lower than stock too. I'm 5'6" on a sunny day and I can flat foot very easily.
Make it work, make it fit. Part of modifying things from stock.
Old Mar 8, 2016 | 05:50 AM
bill1nat's Avatar
bill1nat
I was always afraid to use lowering blocks, since they change so much of the ride. I sent my shocks from my 08 Ultra to
http://bitchinbaggers.com/products/drop-shocks/
they will cut to any size you want and they are still adjustable. They worked great for me
Old Mar 8, 2016 | 06:16 AM
dr2152's Avatar
dr2152
I used the Burly lowering blocks on my 14 Limited. There is no difference in ride or handling. I'm 5'7" also so the lowering blocks and mean city cycle seat mod make me flat footed. 2 up riding 40% of the time. 8k miles and no problems.
Old Mar 8, 2016 | 06:39 AM
barrygreen's Avatar
barrygreen
I had the kit on my 14 FLHXS with the premium shocks and found out after some hard riding in corners the bottom of the shock rubbed the bag.
Looks like he has sense added bag spacers and the statement " FOR AIR SHOCKS ONLY"
So I guess if you have air shocks your good to go!
Old Mar 8, 2016 | 06:52 AM
dontdropit's Avatar
dontdropit
Active Streak: 30 Days
Active Streak: 60 Days
I did the bitchinbaggers thing
Old Mar 8, 2016 | 09:23 AM
Echo6 Sierra's Avatar
Echo6 Sierra
I just installed JNR Designed air ride on my SGS. It's like the Dirty Air system; I installed over the winter and it was very straight forward. I took it around the block when we had a break in the snow, and it felt good. I'll post up more once I get the forks back on. Went with the Legend -1" kit up front.
Old Mar 8, 2016 | 04:38 PM
Punjabi Rider's Avatar
Punjabi Rider
I made my own spacers for the same kit after it rubbed on one bag but now with their spacer kit you should have no issue IMO.
Old Mar 8, 2016 | 07:45 PM
dproto09's Avatar
dproto09
I have tamarack lowering bracket doesn't come with the spacer for the saddler bag. I took off of my 2015 SGS when I went to air ride if interested. $60 shipped.
Old Mar 10, 2016 | 11:26 AM
load97's Avatar
load97
Thanks OP. While checking your link out I ran across these below. Which I ordered up right away lol. see how well they work. Last year I was looking for a 1.5" drop to use with the HD 13" air shocks, but didn't find anything. They were all 1,2,3,".
I see this kit is out now. http://www.ebay.com/itm/131707629140...49e3576d5&cp=1
