Limited Low jiffy stand on regular Limited?
Will the side stand from a Limited Low work ok on a standard Limited Rushmore bike? The tang on my jiffy stand failed from metal fatigue and won't stay upright. It drags in left hand turns and is very hard to retract so I'm getting a new stand. I thought I'd try the Low version if it
doesn't make the bike lean anymore while its on the stand. Or cause any other problems. Anyone swap side stands? Thanks, HMT
Originally Posted by stro1965
I haven't tried it but it would seem to me that your bike would lean over further? I assume the angle of the stand is different on the low?
Its a 2015. I've tried at a couple of dealers and they claim normal wear and tear. No warranty. One service manager took a crescent wrench and bent the tang back up. It only lasted a couple of days and its as bad as ever. I've had several touring bikes and never had a issue with any of the stands till this one, 12,00 miles and its shot. I'm gonna order a low one and Remove mine and compare the length of the 2 when I pick it up. I don't want it leaning over any farther than it needs to.
Originally Posted by heavymetalthunder
The 2015 Ultra Limited and the Street Glide share the same part number. So I'm hoping its just the difference in the tang that gives the low a different part number.
I do believe they are the same jiffy stand - Only the LOW had a different tang on it, so us short riders can reach it with our boot...
...I bought a Limited LOW and took off both rear and front suspension and installed standard height.. left stand and NO issues..
I have to agree withhpsoldier3 - if your bike is a 2015, then it is under warranty - such should not be considered normal wear and tear.
Curious - how much did the service manager charge you to bend it back? Nothing - hummmm, really..hummm, Sounds like he knew it was warranty and worked on it for nothing.
I have chrome speaker covers on my bike. Got home one day and noticed they were missing two screws and a third was loose. I thought, who in the world tried to take my covers - and purchase new screws.
Days later, they were loose again - so I went to the dealer. Service writer said it was not a warranty item. I grabbed the service manager to have him explain. He took a look at it and said, something must be wrong. After some research, discovered there was an issue with the covers and it needed something different. He replaced everything (screws and settings). Problem resolved and it has not been an issue since.
Don't let anyone take advantage of you like that - you did nothing wrong.
