Rushmore touring neck bearing swing back
I attempted to perform the swing back test, as outlined in the service manual, on my 19 RG. I even leveled the bike as specified in the FSM. Problem is I could only get 1 of the 2 required steps to pass, no matter how tight or loose I adjusted the steering stem.
Heres the issue: Step 1 mandates that marks (3) must stop between marks (1) and (2). No matter how I adjusted it (tight or loose) It wouldnt pass this step. Marks (3) wouldnt even come close to stopping between marks (1) and (2).
Step 2, on the other hand, worked perfectly. The tighter the steering stem is, the wider the distance is between marks (3). You adjust the neck bearing to achieve the dimension between steps (3) as specified in the FSM, depending on model. No problem whatsoever with this step.
Im ready to call BS on step 1. I would really like to talk to the engineer at the HD factory that came up with this. That would never happen; they would just tell me to take it to the dealer .I seriously wonder if the dealer performs this step.
My bike is fine and Im happy with the neck adjustment even though it fails step 1 miserably.
I dont have a PDF of the procedure to post, but Doc Harley explains it well starting at the 4:40 mark in this video: Notice the bike in the video also doesnt pass step 1.
at all and then backing off just enough so that it moves freely. Be su
I dont have a PDF of the procedure to post, but Doc Harley explains it well starting at the 4:40 mark in this video: Notice the bike in the video also doesnt pass step 1. https://www.youtube.com/watch?v=uJzQPsE4AoE
It's supposed to be free enough that momentum carries it back through center, but not so tight that it drags to a stop before it's natural spot (mark 1). It's supposed to swing from mark 2 on the right side to between marks 1 and 2 on the left side.
I have worked the adjustment more than several times to make sure the bike does not to get stupid over high speed bridge/pavement transitions and minimum wobble from tar snakes. Shock oil or expensive shocks/forks helps too and don't forget the tension on the riser bolts!
The book does not indicate as it should that the fall away or swing back changes due to the amount of weight on the front end. The swing back gets shorter as you add the weight of the fairing, lights etc.
This is what works for my ride
With the bike level both ways push the front to one side and release
Count the swings and see where it comes to rest
It should come to rest at center in either direction the swing
Mine is currently set - from max left or right with everything attached it swings once across and comes to rest at center. 1.5 swings
From the factory it was set at 2.5 swings as i check it when delivered
I was never happy with it that loose so i have been working it to figure out the sweet spot.
YMMV
