Oil Archive (no new posts) An archive of oil related questions and comments.
..one more post on OIL
Old 04-10-2010, 09:28 AM
JaronB's Avatar
JaronB
JaronB is offline
I use AMSOIL also and bike runs smoother to me and quieter in motor noise. I like it and sticking with it.
Old 04-10-2010, 08:36 PM
barnsleyer's Avatar
barnsleyer
barnsleyer is offline
Stage III
Default Oil Types ?
Hi,
I drained my chaincase by mistake on my 2008 FXD, Its Sunday & I want to go for a ride but dont have any formula+ oil ? can I use another type of oil please ?
Old 04-10-2010, 08:46 PM
xwhyz1959's Avatar
xwhyz1959
xwhyz1959 is offline
Received 1,423 Likes on 455 Posts
Search the forum for oil topics. You can use all kinds. There are even folks running ATF. As long as is doesn't contain friction modifiers, you will be OK. Can you get a hold of some Syn3?? Amsoil 20/50
Old 04-10-2010, 08:49 PM
xwhyz1959's Avatar
xwhyz1959
Old 04-10-2010, 09:25 PM
barnsleyer's Avatar
barnsleyer
Stage III
Not sure ? Do they have it in Australia ?
Old 04-11-2010, 12:37 AM
archergodwin's Avatar
archergodwin
archergodwin is offline
Any good non-synthetic will be fine for your primary. I would try to get a 20/50, but in a pinch 10w/40 will work fine. Even a straight 30w would be okay in a pinch. 1qt.
I have run ATF in the primary before, and I would not suggest you do that. Great for the clutch... not so much for the chain.
Old 04-11-2010, 08:03 AM
Ring's Avatar
Ring
Ring is offline
Thanks for the input guys. Sounds like everyone agrees that using a synthetic is worth the money. As for the brand I think I will try the Amsoil and see how I like it. Thanks again!
Old 04-11-2010, 08:09 AM
bord3r's Avatar
bord3r
bord3r is offline
I use amsoil as well... and to tell you the truth i used it on a sportster that had one oil change and 20 thousand miles on it and when i bought it i knew that i got from a buddy of mine that said he wanted to see how far the bike would go on one oil change well it had 20 k on it when i bought it and i changed the old nasty broken down amsoil replaced it and the bike ran like brand new.. i wont ever change.
Old 04-11-2010, 08:36 AM
ev780's Avatar
ev780
ev780 is offline
Originally Posted by Ring
I've been reading alot of posts on here about engine oil so I don't want to beat a dead horse.......
<snip>
Beaten into a fine pulp, dried, and smoked!!!!
Old 04-11-2010, 09:39 AM
PoCoBob's Avatar
PoCoBob
PoCoBob is offline
I've been coming here for 4 years and in that time nobody has ever posted something saying they had a oil related parts failure when using any brand of oil that met the Harley specs. So it seems that as long as you use the right weight and specs of oil recommended you should be fine.
For the record I have Mobil 1 sync in the motor, Redline MTL in the primary and Redline Heavy Shockproof in the tranny.
Quick Reply: ..one more post on OIL
