Oil Archive (no new posts) An archive of oil related questions and comments.
Amsoil Usage Question
Old Jul 16, 2010 | 07:03 PM
lhgdale's Avatar
lhgdale
Default Amsoil Usage Question
I'm gonna make this short and sweet. 2010 Dyna Wide Glide.
Putting Amsoil 20w50 in engine.
Amsoil Severe gear 75w-140 in trans
All they had was Series 2000 20w50 Severe Service Racing Oil. I plan on putting this in the primary. Will this be ok? I was planning on putting the 20w50 motorcycle oil in the primary anyway but they only had enough for the engine.
Thanks for the reply... I know this has been beat to death!!!!!
I just don't want to do any damage.
Old Jul 16, 2010 | 08:06 PM
dynarule's Avatar
dynarule
You might not want to put that in your primary, it may not be good for the clutch. You could just use the MC oil in the primary and sub the one qt of racing oil in the engine. Or just get a qt of HD F+ for the primary, it works great!
Old Jul 16, 2010 | 08:21 PM
lhgdale's Avatar
lhgdale
Thanks, thats what I was thinking. The engine calls for 2.5 quarts for wet applications, so I will just use the 20w-50 racing oil as the .5 part of that. I will put the 20w50 motorcycle oil in the primary.
I'll be ok mixing the two in the engine right?
Thanks again for the response.
Old Jul 17, 2010 | 03:23 PM
lhgdale's Avatar
lhgdale
I'm about to change the oil, just double checking that it will be ok to mix the .5 of racing oil with the motorcycle oil.
Thanks
Old Jul 17, 2010 | 03:34 PM
soft 02's Avatar
soft 02
same brand+ both syn+ both 20w50. Only difference is additives+ should be fine but its your scoot. I would do it if it was mine but I'm just an old mechanic not a technition.
Old Jul 17, 2010 | 03:42 PM
lhgdale's Avatar
lhgdale
Thanks for the response, I'm about to do it.
opiate9680
May 12, 2020 11:24 AM
blackflame
Jun 4, 2014 09:42 PM
spike95
Apr 7, 2013 09:48 PM
Panchorelly
Sep 11, 2012 05:09 PM
ranger50
Jun 4, 2011 05:35 AM
