Oil Archive (no new posts) An archive of oil related questions and comments.
Bearing SKATE????
Old 09-29-2006, 10:27 PM
Honus's Avatar
Honus
Honus is offline
Default RE: Bearing SKATE????
Folklore! Besides that, Syns are not as "slick" as some animal oils.
Old 09-30-2006, 02:34 AM
wlbowers's Avatar
wlbowers
wlbowers is offline
ORIGINAL: abjones
Bearing skate? I have heard the synthetic oils are so slik that a roller bearing will skate or slide on shafts instead of roll in the cage, resulting in flat spots on the bearings and damage to shaft ends. I want to get as much life out of my engine as possible, since the harley engine is cramed full of roller bearings. I am not sure i should keep running the the synthetic. Amsoil 20/50 in primary and engine, Amsoil 75/90 in trans. Hope some of you wrenches out there have some good information on this subject.
ABJ
Total BS!
I run Mobile V-Twin in the engine and primary. Mobile Synthetic 75/90 in the trans.
Old 09-30-2006, 06:05 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
Mobil1 Vtwin Engine, Redline MTL Primary, Redline Shockproof Heavy trans.........no problemo
Old 06-23-2014, 04:29 PM
Ron750's Avatar
Ron750
Ron750 is offline
Received 16,518 Likes on 6,271 Posts
I am reviving this thread, because it is the only one I found on a search for "bearing skate".
I would like to switch to an Indy, and I called a local one. I asked him if he could use Mobil 1, which I used for my last oil change. He said he didn't recommend it, it is too slippery and causes bearing skate, and I should use Amsoil in all 3 holes.
Is he full of it?
Old 06-23-2014, 04:55 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
Yes he is! RUN!!!
Just yesterday I had an indie telling me syn would make all my seals leak cause it is too slick.
Old 06-24-2014, 10:10 AM
qtrracer's Avatar
qtrracer
qtrracer is offline
Let me guess, he sells amsoil, right?
Old 06-24-2014, 02:02 PM
st john's Avatar
st john
st john is offline
Default Run run run
Is he full of it?
Your indy is doing and saying what is best for him not for you. Double .
Old 06-24-2014, 04:19 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,545 Likes on 4,637 Posts
I am reviving this thread blah blah blah
Did you bother to read the old posts in this old thread?
The question had already been answered.
Old 06-24-2014, 04:55 PM
Ron750's Avatar
Ron750
Ron750 is offline
I didn't know this was the end all and be all of all oil threads. Why bother replying if you have nothing to add?
Some guys bitch if you revive a thread, and others bitch if you don't do a search. I don't feel bad about reviving this thread at all.
Old 06-24-2014, 06:53 PM
Dan89FLSTC's Avatar
Dan89FLSTC
There was nothing to add to this ridiculous question.
The thread was dead, with good reason.
You said you revived this thread because you only got one hit when he googled bearing skate?
Try Harley bearing skate, about a zillion threads already out there, and they all come to the same conclusion.
This is just about the most beat to death myth on any Harley forum.
jokenroll
17
11-26-2012 11:01 PM
bullelkklr
35
12-07-2010 07:51 PM
Roofighter
14
03-29-2008 01:54 PM
black dyna
01-04-2008 09:52 AM
usacando
14
04-03-2006 12:43 AM
Quick Reply: Bearing SKATE????
