Look at the left side of the trans Facing toward the front and to the right of the ratchet shifter you will see the switch HD P/N 71507-64A
Subj: Neutral switch on 1965 Pan. Thanks for the tip. The switch was right where you said. The wires just push into the socket(s), and one of them had come loose. Do you know if this style switch was OEM? Book shows screw type connectors.
