Mueller Motorcycle Power Clutch 2.0
To do this, Mueller revised the ball bearing pockets on each disc for a smoother ramp and also now include a brass clutch cable tensioner to replace the flimsy, OEM plastic unit that relies on a spring to keep the clutch line taught. These two components together, when properly installed, reduce clutch lever effort by up to 45%. If you spend a lot of time in traffic, or in an area with a lot of traffic lights and stop signs, this is the kit your clutch hand needs!
Engineered with ruthless German efficiency in mind, each kit is backed by a lifetime manufacturer warranty and comes complete with easy-to-follow installation instructions.
Available for cable operated clutch Milwaukee Eight models, get yours by calling TJ on 888.575.6570 ext. 817 or email forums@partsgiant.com and be sure to mention you saw this post on HDF and hell get you sorted out, fast!
Contact us for discounts exclusive to HDForum members. Some exclusions apply.
Email: forums@partsgiant.com
Phone: 888-575-6570 ext 817
www.partsgiant.com
