Hard shifting
Hard shifting
I've been looking through the forum and haven't found what I want to know yet. I did see a couple things metioned but I've tried these.
The deal is my 98 Ultra Glide is all of a sudden starting to shift hard into 3>4>5. It down shifts no problem and going from 1>2>3 is no problem either. I adjusted my clutch cable because it was a little loose and checked fluids and everything is fine. I haven't adjusted the clutch yet but will do that next. Does anyone have any other ideas?
RE: Hard shifting
One thing you might want to check is the forward control bushing... When I bought my bike the guy had got it back from the dealer a few months prior with a shifting problem into 3rd, 4th and 5th. The dealer put a new clutch cable on and adjusted the clutch and declared it was fixed. I wasn't satisfied with the shifting and when I took the shifter mechanism off it was not getting grease to the inside bushing and had worn down the bronze bushing. I bought one close to the size from MSC, machined it to the right size, pressed it in and greased it up real good. Now it shifts beautifully... I saw the previous owner a few weeks ago at a restaurant and he asked if I had any shifting problems and when I told him what I found he got pissed (at the dealer) and wanted to know if I had taken any photos so he could try to get some of his $$$.$$ back from the dealer.... too bad I didn't....
Crimson
09-10-2013 02:33 PM
