Do I need to adjust my clutch or is something else wrong?
I'm thinking I may need to adjust my clutch so that it engages later upon letting it out and fully disengages even if I have it a hair away from fully pulled in. Does this sound like it could be the issue or should I have the dealer look at it?
I know some people said it would take some time to wear in, but it seems to be getting worse and not better and certainly on a long ride I could be being lazy with my clutch pulls making the problem worse. I shifted a ton during my 2500+ mile trip so if it was break in I'd think that would have made it better.
Any suggestions would be appreciated.
There are two clutch adjustments and you may need the second, more in depth one done, not just a little cable slack on the cable.
WHY HIT/STOMP on the shifting lever??????????
These bikes need to be treated a little better.....
IF you firmly push/press NOT POP or HIT the shifter and HOLD it UNTIL Fully Engaged,,,,,,, IT should shift the first try....
Old School never changed on these newer bikes...........
SEE I told you would NOT like my Response.....
Learn HOW to ride would be a first thing needed........
signed....REDHEAD
ADDED today:
YES the clutch is way out of adjustment BUT Easy Does IT..
You should be able to shift the bike using the throttle and Leaving Off and On it...
Holding the shifter lever in the shifted position is Important follow through UNTIL it has fully shifted...Especially when the clutch is Not adjusted properly...
For ME, I Become "ONE" with my bike... Think about THAT statement for a while................
Believe me, I do ALL my own mechanical work and really can appreciate riders Who take care and KNOW HOW to use/ride their bikes...
Become ONE with your ride and it will serve you better.
YES adjust the clutch... You can bend the mechanical things inside the shifters and then it will be questions like "WHY does my bike Miss a shift or grind the Dogs when shifting????" I Use sin 3 in the tranny...
WE see it here all the time on the forums...
It is like the rider that asks...
"Will My RPM change when MY shop Indy makes my 96" into 103"...?????
For Crying Out Loud....... LEARN the mechanics about you ride....
Usually it is some rich pert that can run it to the shop and just say fix it..OR go trade it off for the next years model.... Just because he can....
Nothing Wrong with that "IF"
I find Most who do their OWN work, Take Better Care of the stuff they repair.....
LOVE to ride is what it's ALL about then the Journey......
signed....REDHEAD
signed....REDHEAD
