Shifting problem
Old Jul 31, 2010 | 07:44 PM
silverbullitt's Avatar
silverbullitt
Default Shifting problem
Since I changed to a stainless clutch cable, bike upshifts perfect. Downshifting requires way more pressure on the shifter than normal and neutral was hard to find. So, after reading countless "clutch adjustment" tips, I gave it a try today. Didn't make any difference, matter of fact it's a little worse. What am I overlooking? Now, when I pull the clutch in and shift into first, the bike wants to creep forward. It is an 05 Road King Police. Didn't have this problem before I changed the cable (handlebar upgrade, longer cable). Any help? Thanks.
Old Jul 31, 2010 | 08:29 PM
Jackie Paper's Avatar
Jackie Paper
Default Adjust
I am assuming you did this your self and know what I am talking about without a lot of detail. Loosen clutch lever free play. Then insure clutch adjusting screw is only screwed out 1/2 turn from the all way in. Then make sure clutch cable has at lest 1/16 free play at clutch lever bracket. I think most tend to get too much free play and loose some of the movement to fully release the clutch plates. Up shifts are OK like that but downshifts and neutral is a problem Also until you solve your problem be sure you have formula+ in the primary. It works well and then if you want to experiment with all the other oils you see on the forum fine.
Old Jul 31, 2010 | 09:42 PM
silverbullitt
Thanks. I have a little more free play than that, so tomorrow I will give it another shot. I do run Formula+.
blcarizona
Jun 9, 2017 10:03 PM
Jonesee
Sep 30, 2013 09:39 PM
Slammed-N-Senseless
EVO
Aug 13, 2013 10:00 PM
pwoods
Jun 28, 2013 08:41 AM
nightie
Aug 24, 2012 09:51 AM
