Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
What's wrong with my clutch
Old 04-02-2015, 11:42 AM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,334 Likes on 11,164 Posts
Default What's wrong with my clutch
My ride: 2012 Ultra TriGlide; SE 255 Cams; Syn3 in primary; stock clutch; 10k miles.
When the engine gets hot, the clutch misbehaves when starting out. I don't know what it is called, but it kind of grabs off and on. Years ago cars that had gunk built up on the flywheel we called it chattering...but it did it all the time. Mine only does it when it is hot. Before it gets hot the clutch engages nice and sooith and hooks up solidly. It never slips when shifting, even if I am really getting on it.
Is this just classic slipping? Would it only slip starting out when it is hit, and would it be grabby if an on until the clutch is fully engaged?
I'm going to take it to the dealer soon for the 10k service, and will have them look at it...but I would like to be prepared.
I appreciate your insight.
Old 04-02-2015, 11:55 AM
103 sedona orange's Avatar
103 sedona orange
103 sedona orange is offline
Sorry, I wish I had an answer for you. Let's know what solved your problem. I change all my oils at every 5K. Just my 2 cents. Good luck.
Old 04-02-2015, 01:59 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
Is it a cable clutch? If so is the cable close to the exhaust?
Old 04-02-2015, 02:30 PM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
You say "slips when starting out" you mean when you're taking off? Usually if a clutch is going to slip it will do it in the high gears first 5th-6th long before the low gears.Here is something else to think about, bear with me. Put the bike in third gear let the clutch out about half way. Is the handle moving in your hand?
Here is why? http://bakerdrivetrain.com/street-door
A helical cut gearset has a condition known as axial thrust where the transmission shafts push away from each other one of those shafts is your main shaft that the clutch rides on. So if the shaft is moving so is the clutch and possibly disengaging the clutch plates. If your dealer cant find a reason or you run out of options you may want to give the street door a try.
Either way report back with the dealer's findings and we'll go from there.
Old 04-02-2015, 04:54 PM
TriGeezer's Avatar
TriGeezer
Mark, Soft
Yes, I meant when taking taking off. I'll give your experiment a try.
I'll also check out the clutch cable routing as soft02 suggested.
Old 04-02-2015, 06:39 PM
checkers's Avatar
checkers
checkers is offline
If you are running synthetic oil in your primary, you want to change to a dino oil such as Rotella 15w40. Ride it of a few hundred miles. It will feel different and better. My opinion. Is the clutch basket adjusted correctly or due.
Old 04-02-2015, 10:03 PM
TriGeezer's Avatar
TriGeezer
Something else to try. I do feel suspicious about the sny3 since the issue seems to be thermally related.
This weekend I'm going to do the tests Mark suggested. Check on the cable routing. Swap out the syn3 for HD formula+.
HDJIM1158
Milwaukee Eight (M8)
100
12-07-2021 10:50 PM
ultrawing
2014-2023 Touring Models
05-23-2015 08:42 AM
wdb1264
01-01-2015 10:23 AM
Willetts1
02-16-2014 09:41 PM
bigredwing
09-01-2011 11:00 AM
Quick Reply: What's wrong with my clutch
