Inner Primary bearing issue ?
I think I have an inner primary bearing problem. When I start the bike I hear a different sound coming out of the primary case then when I pull in the clutch and drop it in gear it goes away. How hard is it to change out this bearing if you all agree this is more than likely my issue..?
Thanks
Thanks
I think I have an inner primary bearing problem. When I start the bike I hear a different sound coming out of the primary case then when I pull in the clutch and drop it in gear it goes away. How hard is it to change out this bearing if you all agree this is more than likely my issue..?Thanks
Or you can spring for the R/R tool from various suppliers.
http://www.ebay.com/sch/i.html?_nkw=harley+bearing+tool
Get the service manual for your bike and study. The work is not hard but dirty and time consuming but you will save yourself a wad of $$ by taking on the task by yourself. The bearing can be removed by taking a Dremel tool and cutting a notch in the bearing being careful not to go too deep and cut the main shaft. Insert a chisel into the notch, bump it with a hammer and the race will break; very brittle. You can install the bearing with some PVC pieces and the main shaft nut. You can purchase an installer from various online sources or go caveman per the photos. Start with a piece of Sch 40 PVC 1.25" long as far as you can go with the main shaft nut and then replace it with a piece 1.75" long. Photos attached to illustrate.
You are correct, my mind sometimes works faster than I can type and I drop a word here and there. I dropped the word "race" but have corrected my post. Have replaced a few without the special tool and always replace the bearing with OEM piece. I use the S&S race but it is not available for the '07 and later models.
I don't disagree that the problem might lie elsewhere but the OPs statement "When I start the bike I hear a different sound coming out of the primary case then when I pull in the clutch and drop it in gear it goes away" points directly to the IPB or the race.
As you know, sometimes the race has walked in enough that there is insufficient space for the puller tool to fit and the Dremel comes into play.
