Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
i just removed my primary to change the seal on the trans and not familiar with the hydraulic clutch ! any help would be appreciated clutch is the jay brake set up and its a bdl primary
Not sure on the Jay brake set up but here is how ours works:
Open the bleeder screw.
Turn the adjuster screw all the way in so the piston is fully bottomed out.
Back the adjuster screw out a half turn and lock down the nut.
Bleed the system and you're done.
