Open Primary.
Old Jul 30, 2018 | 09:13 AM
Big Sack's Avatar
Big Sack
Default Open Primary.
Am running a 3" BDL on the 120 Ultima. The bike has a slight urge to drive when clutch is disengaged. Am I able to get this adjustment out of the clutch itself or is it best to get the adjustment out of the cable??
Don't have much experience with the open primary.
Old Aug 1, 2018 | 10:43 AM
Max Headflow's Avatar
Max Headflow
You probably need to rebuild the clutch.. New outer steel pins and plates. I'd also pull the clutch and check the splines on the inner hub.
Old Aug 3, 2018 | 10:56 AM
misfitJason's Avatar
misfitJason
Re-adjust both. If it's a bdl it's a different adjustment than a stock clutch. Bdl clutched only need to be a 1/4-1/2 turn out.
Old Aug 3, 2018 | 11:22 AM
Max Headflow
Adjustment procedure here.
http://beltdrives.com/install-guides...arranties-page
Chappull
Apr 24, 2016 03:16 PM
jrwca
Jul 1, 2015 07:31 PM
gant
Mar 26, 2013 07:41 AM
55chevysa
Aug 27, 2009 10:11 AM
03eglide
Nov 5, 2008 12:14 PM
