Is it Doable??
Is it Doable??
On a '16 Ultra, can I change the diaphragm spring effectively, properly without pulling the primary cover? Not sure if you can get to all the screws with a torque wrench and such. Haven't done it before, but I changed my 5, 000 mile primary fluid and it smelled badly of clutch. Changes out cams 5K ago and I think it needs a spring.
