Clutch cable leaking oil bad
i just replaced my clutch cable when I put apes on my 2014 road king and now it is leaking a lot of oil from the cable where the cloth wraps around the braided cable. Where it comes out of the trans housing and goes under the timing cover. It is a magnum shielding chromite cable. Do I need to tighten it or redo the whole install?
For all interested, if you have the same problem trace your cable all the way down and make sure it isn't too close to the exhaust. Mine was routes too close to the exhaust and it burned through the coating on the cable causing the fluids from the transmission to leak out onti the exhaust. I'm lucky I caught it before a long ride. I could see that catching on fire at some point.
