Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Does the 30T primary sprocket and chain for the touring bike fit a 2015 dyna? Is the clutch spring the same too?
I thought they are the same but when I looked it up found conflicting info.
Thanks
Thanks
Sprocket will but chain won't Primaries are different length. Clutch spring should be the same fit.
