Dyna won't move
Old Jun 28, 2018 | 06:52 PM
fxdx-fxr-xlh's Avatar
fxdx-fxr-xlh
3rd Gear
Default Dyna won't move
Hi guys looking for some help with my 02 fxdx. I'm not new to wrenching on my bike but I'm stumped on this one. I just replaced my inner primary put everything back as it was and to owners manuals specs as I bottoned everything up and went to take it for a ride I came to realize 1st thru 4th bike won't moves all if I put it in fifth and release the clutch the gear engages and bike moves clutch lever feels as normal as before I did the inner primary please hit me with whatever info you got thanks in advance
Old Jun 28, 2018 | 07:17 PM
Jackie Paper's Avatar
Jackie Paper
What did you do in the primary? Maybe, primary chain way too tight if all was ok before your started.
How did you lock it up to break comp and clutch nuts?
Old Jun 28, 2018 | 07:51 PM
fxdx-fxr-xlh
3rd Gear
Yes all was good before hand just replaced the inner and put it back together I'm gonna pull it all back apart tomorrow I just don't know if its something I did putting the primary back on I just don't understand what could make this happen I have the stairway block to break the compensator sprocket and clutch so clutch comes off all together
Old Jun 28, 2018 | 08:20 PM
misfitJason's Avatar
misfitJason
You either didn't tighten the clutch gun but or compensator or......what my money is on is that your screwed up the clutch adjustment
Old Jun 29, 2018 | 12:54 AM
Krazy8s's Avatar
Krazy8s
Clutch adjustment is also my first thought. Or you left the bar in there between the comp and clutch after you torqued them up.
Old Jun 29, 2018 | 04:42 AM
misfitJason
This just popped into my mind.
YOu didn't by any chance leave out the clutch pushrod that goes through the trans did you
Old Jun 29, 2018 | 04:49 AM
fxdx-fxr-xlh
3rd Gear
I thought about that but its in there. and clutch is adjusted rite too the best of my knowledge feels good at the lever pulled the derby cover and fired it up clutch spins and seems to engage when I pull the lever when I go to shift into first it feels like its not letting it go into the gear neutral light comes on in neutral and goes off when I try to shift but its not there bike will role freely
Big Sack
Custom Models
Aug 3, 2018 11:22 AM
SportsterSnow
Jun 14, 2013 09:14 PM
Jonathon Beaudin
Shovelhead
Jan 6, 2013 04:00 PM
55chevysa
Aug 27, 2009 10:11 AM
03eglide
Nov 5, 2008 12:14 PM
