Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
BDL Dive Problem
Old 12-19-2005, 11:12 PM
rwhitesr's Avatar
rwhitesr
rwhitesr is offline
Stage III
Default BDL Dive Problem
I am building a custom 96 FXR w/new EVO and 5-speed. I have installed a new bolt on BDL drive and having a big tracking problem. I tried spacers, no good. I tried adjusting front mount shackle, no good. Should I try the top shackle. I am at wits end. Bike is just about completed except this problem. Any suggestions would be greatly appreciated. Rich White
Old 12-20-2005, 12:09 AM
pococj's Avatar
pococj
pococj is offline
Received 1,212 Likes on 462 Posts
Default RE: BDL Dive Problem
Have you done the straight edge thing on the pulleys to make sure they are actually aligned properly?
Old 12-20-2005, 07:25 PM
rwhitesr's Avatar
rwhitesr
rwhitesr is offline
Stage III
Yes I think I did it correctly. I think I am going to try loosening all of the front mount bolts and the inner primary bolts to see if I cacock the engine shaft just enough to keep the belt from tracking outboard. Rich
Old 12-22-2005, 04:06 PM
HDWRENCH's Avatar
HDWRENCH
HDWRENCH is offline
If you have the pulleys correct it should track properly unless some thing is loose ?? O loosed the engine, and trans get it correct and then snug engine and trans down recheck and tighten both. Are you using a one or two piece plate??
Old 12-23-2005, 05:57 PM
rwhitesr's Avatar
rwhitesr
rwhitesr is offline
Stage III
what does 0 loosed mean and what do you mean by one or two plates. I have no plates. Rich
Old 12-26-2005, 01:18 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,300 Likes on 3,656 Posts
If the belt is just tracks to the outside edge of the pully, you are probably OK. If it trying to climb over the the lip you've got problems. Does it hit the edge of one pully first? Check with a straight edge but also check to make sure that the pulleys run in the same plane. You can tell by using a straight edge at top and bottom of the pulley but two verticle straight edges and an eyeball works better. I assume this is a 3 inch open? Bruce
Old 12-27-2005, 08:27 PM
8 UP's Avatar
8 UP
8 UP is offline
It must be alined In all three plains, I use A 1" wide x about 15"-18" long piece of glass.
Lay It across the top of the pulleys and gentely tap the glass In the middle.
If you can hear It raddle, Its not in alinement.
Loosen things up & check until you have no raddle, then snuge things up, check again.
If still no raddle, tourqe It down.
Old 01-23-2006, 12:17 AM
fasteddie's Avatar
fasteddie
fasteddie is offline
I had the same problem with the belt trying to track off the front pulley I tried about 5 different thickness shims and it turned out to be I had to use the big thick original spacer about .200 thick and a .010 thick spacer that goes between the compensating sprocket and the alternator rotor >>this is on a enclosed 1-5/8 wide belt been over a year the belt is tracking straight about an 1/8 inch in on the edge of the front pulley>> hope this helps you
Old 01-23-2006, 12:22 AM
fasteddie's Avatar
fasteddie
I contacted BDL one time and the tech told me to turn the belt around and see if it tracks any better in other words make the letters face in instead of out the tech told me once in a great while the belt is not cut or formed perfectly straight
thewoozel666
07-31-2016 03:01 PM
drawson
04-01-2016 06:48 PM
berndog
Shovelhead
09-06-2014 10:16 PM
gioss
EVO
03-16-2012 09:57 AM
Velocity1
02-19-2007 07:17 AM
Quick Reply: BDL Dive Problem
