Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Is it True about Heritage Springers?
Old Jan 23, 2006 | 01:06 AM
jcarlos's Avatar
jcarlos
Default Is it True about Heritage Springers?
I have a 97 Heritage Springer and for some reason or another I can’t pop the transmission into neutral when the bike is stopped. The only way I can put in neutral is when I’m rolling to a stop or if the bike is off. I heard that’s just the way Heritage Springer’s are. Has anyone heard of this before? Any other Heritage Springer owners out there with the same problem?
Old Jan 23, 2006 | 01:30 AM
pococj's Avatar
pococj
Default RE: Is it True about Heritage Springers?
It ain't the way any new HD is, and whoever told you that is full of crap. Sounds like a clutch adjustment is needed.
Old Jan 23, 2006 | 02:02 AM
bobcowan's Avatar
bobcowan
No, that's not normal. You have a clutch problem.
Old Jan 23, 2006 | 03:25 AM
chappy's Avatar
chappy
Been There, Done That
Try giving her a slight but quick twist of fuel and just as quick back her off, as soon as the rev's hit peak and start to return to idle you should be able to easily pop it up into neutral from first. As far as the rev goes; we're only talking a couple hundred rev's at the most. Just a quick jab. If you still can't get it into neutral after a few pratice tries then your clutch adjustment is most likely the problem. But, again, even with a clutch problem, in many cases neutral can be had useing the method I just wrote.
chappy
mikes03hd
General Topics/Tech Tips
Aug 22, 2018 09:08 PM
triip1dog
Sep 18, 2017 03:05 PM
scuff1
Sep 19, 2016 04:40 PM
spiritwarrior
Sep 20, 2014 09:10 PM
Mordac
Jan 2, 2012 06:55 PM
