heritage stalls
Old Sep 18, 2016 | 02:02 PM
scuff1's Avatar
scuff1
3rd Gear
Default heritage stalls
About once a tank fill my heritage stalls for awhile when approaching stops. It happens when I clutch slowing down. At the stop sign or light it starts up and idles like nothing happened. What's the deal?
Old Sep 18, 2016 | 02:27 PM
Tampa Fatboy's Avatar
Tampa Fatboy
Not enough info.
Old Sep 18, 2016 | 03:04 PM
dfwhockey17's Avatar
dfwhockey17
There could be a number of issues going on, as mentioned we need more info...
Old Sep 18, 2016 | 03:19 PM
JustDave13's Avatar
JustDave13
My 2013 has done that a few times, not lately though.
Old Sep 18, 2016 | 03:47 PM
Joe_G's Avatar
Joe_G
What year bike? Carb or FI?
The ignition switches get gummed up and cause intermittent stalling...when it happens the lights go out as if the switch was shut off, which it was due to gummed up contacts.
Here is my thread on how to service your ignition switch.
Old Sep 19, 2016 | 09:55 AM
scuff1's Avatar
scuff1
3rd Gear
Thanks Joe G. It's a 2008 with FI. Your message implied that you attached something but I couldn't find it. Where are those ignition switches? And if that's the problem, how come it starts up every time? Wouldn't the gumming make the restart a problem once and awhile?
Old Sep 19, 2016 | 04:40 PM
mswing1234's Avatar
mswing1234
I had a "similar" problem with my FI 08 Fatboy. Pull in the clutch at stop signs or traffic lights, stall. Start right back up though. I looked through the various forum threads and one suggestion was to clean or replace the idle air control valve. Deciding to start with the easiest, I removed the air intake and shot some carb cleaner in the throttle body a few times. That was two years ago and it's been fine ever since. I later read that carb cleaner was not the best thing to spray in there. I'm sure there's lots of suggestions if you search for "Idle Air Control Valve".
sherifflittle
Jun 14, 2024 05:19 PM
hotroddarin63
Feb 26, 2011 12:39 PM
Softail Girl
Dec 28, 2008 09:36 AM
PUBA ONE
Nov 7, 2008 11:24 AM
idunno
Exhaust System Topics
Jun 3, 2005 06:36 PM
