Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
rear drive belt life
Old 12-18-2019, 06:51 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,854 Likes on 2,420 Posts
Cool
Originally Posted by markoHR
You mention miles. What about the age of the belt? Mine has no damage, I have 16,000 km and the engine is 13 years old. Do I need to replace the belt? Thank you.
No, not in my opinion. Read all the posts above and you will see that our belts generally last a very long time and also very high mileage. I've owned belt-drive Harleys since 1990 and only replaced one due to damage, never had one break. The damaged one picked up a small sharp flint, which punctured it, however I continued to ride with it, checking the wound regularly and only replaced the belt when the wound started to get bigger, several thousand miles later.
If you don't have one get yourself the H-D belt tension gauge and use it at service intervals. It is the only dedicated Harley tool I own! Visually check your belt regularly for any signs of damage.
markoHR (12-18-2019)
Old 12-18-2019, 06:53 AM
markoHR's Avatar
markoHR
markoHR is offline
4th Gear
Originally Posted by Sandcrab
I have 67,400 miles and my belt looks fine. Going for 100K miles.
Thank you. What about the age of the belt? Is it decaying (material) and should it be replaced after about 10 years or similar...?
Old 12-18-2019, 06:54 AM
markoHR's Avatar
markoHR
markoHR is offline
4th Gear
Now i see answer.. Sorry. Thank you!! I agree!
grbrown (12-18-2019)
Super Glidester's Avatar
Super Glidester
Super Glidester is offline
Received 17,622 Likes on 9,825 Posts
I asked the salesman this question when I bought my Sportster, his answer was "youll trade in way before that's needed..." 15 years later, still have my Sportster..what a holes the are/were( the salesmen...)
Old 12-27-2019, 08:34 PM
NORTY FLATZ's Avatar
NORTY FLATZ
NORTY FLATZ is offline
Received 5,435 Likes on 2,969 Posts
I wouldn't worry about the belt agewise until I got to 20 years. That's providing the belt hasn't been abused, nor neglected.
Can't believe I just responded to a 15 year old thread...
markoHR (12-28-2019)
Old 01-04-2020, 10:41 AM
kink04fxd's Avatar
kink04fxd
kink04fxd is offline
Just for fun, the belt on my 82 FLH is 38 years old. Still looks great. Mileage unknown but well over 60,000. I did replace the trans pulley about 25,000 miles ago.
Old 01-08-2020, 09:03 PM
voodoodrug's Avatar
voodoodrug
voodoodrug is offline
mechanic friend said it looked wore,and power can affect its life(not stock), then another mechanic friend looked at it and said how much trouble is a week in the hospital?
500$ and part of a day later...85k miles changed both pulleys and belt. Still have them as back up
tekeum
07-03-2012 02:41 PM
9512valve
13
04-18-2010 06:55 PM
jcboof
03-12-2008 06:52 PM
Mr Wonderful
07-11-2007 10:19 PM
bodyman0
04-29-2007 08:05 PM
Quick Reply: rear drive belt life
