HELP my Trans is stuck
RE: HELP my Trans is stuck
Hey, sorry about your issue...but ...your bein kinda harsh with Anubisss.....dont ya think???
Try this.....pull in the clutch, fire up the engine, with the clutch in, try running it thru the gears a couple of times, then hit neutral again and see if it works. Sounds like your getting a false neutral to me, but Im not an expert by any means. will it roll with the clutch engaged??
If I start my bike andputit in gear, the bike stalls out. The tire will not move. When the bike is in neutral, I can turn the tire about half way in either direction. I am at a loss for words and can't imagine what the problem could be. The bike has sat on my jack all winter and was running fine last season.
o0smitters0o
13
05-08-2018 07:41 AM
