Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
96 Softail Compensator sprocket spring and cup
Old 08-05-2009, 10:56 PM
oldgit's Avatar
oldgit
oldgit is offline
Stage II
Default 96 Softail Compensator sprocket spring and cup
I have a knock in the front of the primary at idle so I took it apart and I noticed today that the cam is sliding 1/2 to 3/4 up the ramps.(looking at the wear) I thought maybe the bolt was coming loose but it was a bear to get off. This bike has a 113 S&S motor, I have read a few threads and believe it is probably the spring has gone bad. I can replace it with a new one but was wondering if there are any other options out there? I saw somewhere a setup that got rid of the spring and the ramps, has anyone tried one of these? Is there any real reason to have the ramps and spring in there?
Thanks,
Oldgit
newdyna
04-12-2016 08:38 AM
dvanhorn
11-26-2012 05:04 AM
300mmsoftail
09-09-2012 12:20 PM
jokenroll
EVO
05-18-2012 11:49 AM
Johneb48
Exhaust System Topics
02-09-2006 06:05 PM
Quick Reply: 96 Softail Compensator sprocket spring and cup
