Weak compensator spring question
Old May 18, 2012 | 10:36 AM
jokenroll's Avatar
jokenroll
Question Weak compensator spring question
Gentlemen,
Does anyone know how to evaluate the condition of the compensator spring/clutch (the round saucer thing just under the compensator nut)?
What happened on my decker a couple of years ago: the rotor fell apart! Metal just around the splines was ripped out the rest of the rotor body completely. I was told that it was probably due to the weakness of the spring (I found the nut itself being torqued properly), so the rotor was somehow moving/vibrating on the sprocket shaft which finally caused that breakage. This problem was solved by buying some aftermarket sealed magnets rotor with thicker body and washers around, so they would supposedly preload that spring well enough. So far it does not give me problems anymore, fingers crossed...
Now, as we know, I am happily installing a brand new Evo on my Heritage. But the bike has way more miles than the decker. Now I am paranoid that its spring is weak as well... Can I check it somehow? Have anyone heard of trimming the compensator nut a bit (so it would compress the spring more)? Maybe I should do just that?
Old May 18, 2012 | 11:49 AM
2006FLST's Avatar
2006FLST
I cannot answer your question BUT.
If you need one I actually have a new one from JP cycles. Long story why I have it . But anyway if you end up needing one I can hook you up. I also have a new cam piece. If you need it I will try to find a link to that part.
Z
Engine Mechanical Topics
Jun 7, 2018 07:09 PM
Ygrider
May 26, 2017 07:31 AM
newdyna
Jan 27, 2016 09:28 PM
kylebryan
Sep 30, 2015 12:11 AM
akira
Ironhead
Apr 16, 2006 05:49 PM
