Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Primary Noise
Old 03-14-2010, 07:22 PM
2005UltraNC's Avatar
2005UltraNC
2005UltraNC is offline
Default Primary Noise
2005 Ultra, with 95CI, Full Ported, 26G cams
Guys, had to pull the primary apart, including the inner primary, to change the transmission lever. The splines worn and the lever was loose.
Any case, after putting everything back together, I picked up a noise when starting. Only lasts for approx 2 seconds and sounds like near the primary chain adjuster and/or compensator.
Did not have a bit of noise before I tore down the primary.
Any ideas why I picked up this new noise?
Old 03-14-2010, 08:58 PM
rbabos's Avatar
rbabos
rbabos is offline
Do you have the HD auto tensioner? If so, some don't like to set the tension correctly without a little finger push to the next click or two. Works out to about 1/4" play in the chain when set correctly.
Ron
Old 03-15-2010, 07:44 AM
2005UltraNC
No auto tensioner. Stock nylon shoe. Did check it and is adjusted okay. I think it may be the inner guts of the compensator. Is it a known issue for these compensators to make noise? It's like something in it continues to spin for a second/two after the engine starts.
Old 03-15-2010, 03:13 PM
DanD's Avatar
DanD
DanD is offline
could it be the starter? I've had to take em back apart because of the rod before...thoh it's been a long time ago since i did.BTW,I had that very same issue with the stripped shifter,and had to replace the shifter rod as well.it sounds like to me,it might be the starter gear spinning.
Old 03-17-2010, 06:16 AM
09DynaMan's Avatar
09DynaMan
09DynaMan is offline
Did you refit the starter drive spacer the correct way?
Was the bearing flush?
Counterbore towards starter?
Starter motor bolts tight?
Starter turned freely by hand when refitted?
SG1stingray
09-19-2011 10:51 AM
RodeoHard
EVO
03-20-2011 10:22 AM
villas-legacy
13
10-06-2010 07:42 PM
2005UltraNC
03-15-2010 08:50 AM
IronmanSwamie
Exhaust System Topics
06-30-2009 09:45 PM
Quick Reply: Primary Noise
