Inner Primary Bearing
Talking specifically the inner primary bearing of course.
I have a threaded rod setup for other things, not beefy enough for this but if that works could put together a beefier setup. Shops charge more than the bearing to press in. Thanks.
(well aware this thread is older but working on a 2008 twin cam)
So one can do this without a shop press? like using a Pit Posse wheel bearing tool would work? Its been a minute but I think I tried that on my 2012 Twin Cam years back and I couldn't get the bearing to budge in the inner primary.
You can also use a 1-3/16" impact socket (for late model primaries) with the tool from George's Garage.
https://www.georges-garage.com/produ...ver-installer/
or purchase the appropriate pilots from Jims.
967-4: Bearing Remover/Installer Cup, late primary
967-5: Bearing Pilot, late primary
DJ Baar
Sep 22, 2011 08:19 AM
itsaw0rkinpr0gre$$
Jun 28, 2011 11:53 PM
JustDave71
46
Apr 30, 2010 12:16 PM
