What causes an inner primary bearing to go bad?
Old Dec 14, 2010 | 10:25 PM
itsaw0rkinpr0gre$$'s Avatar
itsaw0rkinpr0gre$$
"Seeker of Freedom"
Default What causes an inner primary bearing to go bad?
I see quite a few threads that mention inner primary bearings going bad. During the installation of my SE120R engine kit the tech said the only abnormal thing he discovered was the inner primary bearing was showing signs of wear at 15K miles on an 09 street glide. I don't want that to happen again if I can do something to prevent it.
What are the causes of an inner primary bearing failure?
Old Dec 14, 2010 | 11:22 PM
honestbob's Avatar
honestbob
Mine went out at 30,000 miles. It's acually the transmission main shaft bearing. some just call it the inner primary bearing. From what I saw and was told it's the inner race that goes bad. (roller bearing) I went with a fully synthic heavier oil in the tranny and have had no more problems with my 08 going on 70,000 miles.
Old Dec 14, 2010 | 11:43 PM
sifularson's Avatar
sifularson
Originally Posted by itsaw0rkinpr0gre$$
I see quite a few threads that mention bad inner primary bearings going bad. During the installation of my SE120R engine kit the tech said the only abnormal thing he discovered was the inner primary bearing was showing signs of wear at 15K miles on an 09 street glide. I don't want that to happen again if I can do something to prevent it.
Mine started making noise at 28K on my 07. Bearing had 4 rollers failing and the inner race had a bad spot. The bearing hadn't completely failed but it was close.
I have a theory that the bearing design is the issue. Either that or the metal isn't hard enough on the bearing race. I do know that there was a change in the bearing and mainshaft in late 07. I found this out when I ordered the bearing for my 07. Here's the story . . .
I ordered the part # out of my 07 parts book. The bearing I received did not fit the mainshaft. I researched and found that there was an updated part # for the bearing and race. The new bearing race had a slightly smaller ID meaning the newer mainshaft was actually smaller. I suspect that HD went to a harder bearing race or higher quality bearing. Just a guess.
Here's a picture of the two different bearing races. Note the bad spot in the bearing race on the right.
Old Dec 15, 2010 | 12:11 AM
SICKBAGGER's Avatar
SICKBAGGER
from what I understand the bearing itself has a nonmetalic component in it. It is the bearing keepprt if you will don't know the correct term at the moment but you have the outer portion of the bearing the ball bearings and the inner race and then the bearing keeper retainer or what ever it is call around the bearings themselves. This is the component that is failing and allowing the race to walk out of the bearing and along the shaft. I will be going in soon myself how to do the SE comp, inner priamary bearing, clutch plates and a variable pressure clutch spiong assembly.
There is talk on another forum in regards to the compensator and what fluid you are running in the primary. Many have used ATF and other primary fluids but it seems that HD Primary + may be the right fluid. The others work well for clutch perfomance but may lack in in oiling bearings and the compensator.
Old Dec 15, 2010 | 01:56 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
We '06 Dyna owners have had our issues with failing IPB's. In our case, I believe the problem is the lack of 2 alignment dowels btw the IPCase and Tranny Case. After mine failed twice (4K-mi, and 12K-mi), they replaced my -06 part number cases with the -06A cases (with 2 alignment dowels)...over 26K now, and no issues.
In our case, H-D gave early purchasers a "pink letter" stating they were conducting an "Initial Care Program" that amended Owner's Manual service intervals for primary/tranny lube, and allowed free IPB replacement every 15K-mi. (see letter below). Though they sent out a rescission letter later, the cat was out'a the bag regarding the pink letter being a de facto admission of a problem with the '06 Dyna.
I don't think the Touring cases lack the alignment dowels like the Dynas. Many Dyna guys are just replacing the stock IPB with the heavy duty "Baker Bearing", instead of going thru the channels to get H-D to replace the cases with the dowelled ones for free.
Old Dec 15, 2010 | 02:10 AM
emwolb's Avatar
emwolb
this is valuable information guys. thanks, i was not aware that this might be a weak link in current harleys.
Old Dec 15, 2010 | 04:46 AM
itsaw0rkinpr0gre$$
"Seeker of Freedom"
Originally Posted by SICKBAGGER
......Many have used ATF and other primary fluids but it seems that HD Primary + may be the right fluid. The others work well for clutch perfomance but may lack in in oiling bearings and the compensator.
So you are suggesting that using the 20w50 synthetics in the primary may be contributing to the failure of these bearings?
Old Dec 15, 2010 | 06:51 AM
bikehe's Avatar
bikehe
Is this bearing an easy one to replace and are there any special tools required
Old Dec 15, 2010 | 07:08 AM
dFREDb's Avatar
dFREDb
The bearing and seal failed at 25,000 miles on my '08 FXDC. According to tech and parts guys this is an all too common issue since they changed from Timkin bearings. Transmission had to be practically rebuilt under warranty. I would not attempt this job myself until warranty expires. I would think that all you need is a bearing puller and installation driver. If there are metal shavings and chunks, it's time for a rebuild. Cheap azz Chinese bearing.
Old Dec 15, 2010 | 04:57 PM
Punjabi Rider's Avatar
Punjabi Rider
I had mine replaced at 22k under warranty and was told by HD tech to switch to good syn gear oil and since then 56k on it no issues. I use red line gear oil in both our bikes it also helped keeping trannys ltl quite.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
