Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
jockey shift leaks
Old 09-10-2012, 12:43 PM
Smokey Burnouts's Avatar
Smokey Burnouts
Smokey Burnouts is offline
Default jockey shift leaks
Gettin ready to order a La Jockey shift kit and after talkin to a few people they said the clutch cable leaks really bad. This was on a softail and dyna.
Any first hand knowledge of this from any of you jockey shifters?
Thanks
Old 09-11-2012, 12:16 PM
Smokey Burnouts
Lil bump... Anybody got any leaks from the adjuster?
Old 09-11-2012, 01:21 PM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
It is because the clutch cable is too low once you put the bike on the side stand the fluid remaining in the cover leaks out. They way around it is to reroute the cable in such a way that it is above the frame instead of below.
Old 09-11-2012, 01:48 PM
Smokey Burnouts
Ok thanks Mark, so is some truth to it. Does it leak from the end of cable near the foot clutch or from the adjuster?
Old 09-11-2012, 03:08 PM
Adjuster, just route it up around the down tube or some such.
Old 09-11-2012, 03:27 PM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
Mine has never leaked. It has been on the softail for about 3 years and gets ridden regularly.
Old 09-11-2012, 05:27 PM
Smokey Burnouts
How do you have your cable routed?
Is the shift lever in a good position where you dont bump it at stops? The reason i ask is a custom shop here said lots of guy complain about the angle/placement, of course followed by "but i can make you one thats better......$$$$".
Old 09-12-2012, 12:37 AM
PSJBrock's Avatar
PSJBrock
PSJBrock is offline
6th Gear
I think the LA Chopper kits are a waste of money. you can make your own kit for 10 bucks if you have access to a welder. The first jockey shift I had used the stock cable it wrapped around a few times but pull was easy and it never failed. Also mine never leaked either. I have since made a custom cable but the stock one worked awesome.
Old 09-12-2012, 09:52 AM
Lundee's Avatar
Lundee
Lundee is offline
Mine has never leaked. Make sure your o-ring on the trap door side is good. LaBriola makes a good kit, plan on waiting about 6 weeks to get it.
Old 09-12-2012, 10:02 AM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
[QUOTE=Lundee;10322904]Mine has never leaked. Make sure your o-ring on the trap door side is good. LaBriola makes a good kit, plan on waiting about 6 weeks to get it.[/QUOT I was going to mention the same thing. Make sure you use the o ring.
Carter2607@sbcglobal.net
10-20-2017 07:13 PM
Machine213
04-04-2016 09:53 AM
mitchxc700
06-23-2013 03:20 PM
Bleachey
EVO
09-03-2011 09:18 PM
turner8
02-23-2008 01:26 PM
Quick Reply: jockey shift leaks
