Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
primary drive locking tool
Old Jan 6, 2005 | 01:01 PM
Scout's Avatar
Scout
Default primary drive locking tool
Does anyone have a primary drive locking tool (HD-41214) that they can fax me a profile of? I don't feel like paying HD's crazy tool prices when I can cut one myself on the mill.
Old Jan 14, 2005 | 04:50 PM
Scout's Avatar
Scout
Default RE: primary drive locking tool
I broke down and bought it, so if anyone needs a profile tell me. I could have made it for $5.00
Old Jan 14, 2005 | 05:03 PM
12Stones's Avatar
12Stones
You rock Joe. I tried doing a search for it and seeing if anyone I knew had one but no luck. I don't need one; just wanted to let you know we appreciate the offer.
Old Apr 22, 2012 | 10:02 AM
Tltrump's Avatar
Tltrump
can you give me the profile of the locking tool? HD 41214
Thanks
Tom
Old Apr 23, 2012 | 10:52 AM
corliss@bakerdrivetrain.com's Avatar
I wedge an old tensioner shoe between the splines and chain. Very scientific method.
Old Apr 24, 2012 | 04:37 PM
djl's Avatar
djl
The profile is attached. I also took a scientific approach and made my own tool; took a hacksaw to an old lawnmower blade.
Old Apr 25, 2012 | 08:56 AM
M&P340's Avatar
M&P340
djl, what bike did you use that tool on?
Don't know what the op is working on, but a 7.5" tool would never work on my '04 Dyna. I cut the same tool 8.5" long, and it was just a bit short, although it did work & I was able to lock up my primary with it. But an 8.75" or even 9.0" tool would've been better.
Old Oct 10, 2015 | 01:49 PM
rob nighttrain's Avatar
rob nighttrain
Stage I
Default I also want a locking tool
I am searching for a primary drive locking tool to.
Old Oct 12, 2015 | 02:59 AM
Next In Line's Avatar
Next In Line
Less than 30- at George's Garage.
Old Oct 12, 2015 | 03:31 PM
BJB's Avatar
BJB
I was using a piece of oak 1x2 until I cut it too short because the shorter and more direct it is the less strain on the bearings. I kept on shortening and eventually the teeth bit too deep into the wood. Then I just used a piece of scrap steel and measured it. It is 3/16" thick and 5 3/8" , I think. If it doesn't work next time I'm in there to put in the 32 tooth sprocket I'll just make a new one. It isn't that hard.
RK_RIDER
Aug 14, 2011 02:23 PM
Wireguided
Oct 27, 2009 04:56 PM
chiefparry
Apr 16, 2008 12:13 PM
deer30084
Sep 4, 2007 07:29 PM
rob_will
Mar 22, 2007 09:59 PM
