Rockford Fosgate Audio High performance motorcycle audio systems, purpose built for Harley-Davidson.
6 speaker install do I need another amp?
Old Aug 8, 2020 | 09:15 AM
Mikratt's Avatar
Mikratt
Default 6 speaker install do I need another amp?
I have installed the HD14U Stage 2 in my Ultra Limited 2016.
I have two fairing speakers and two tour pack speakers and looking to install saddlebag speaker kit TMS69BL14.
Do I need a second amp to power those speakers?
If so which amp and is there a wiring diagram for hooking up a second amp?
I have a Boom GTS head unit retrofitted and I will be installing a removable tour pack kit also, if that matters.
Thanks,
Mike
Old Aug 10, 2020 | 04:51 PM
Rockford Fosgate's Avatar
Rockford Fosgate
Former Sponsor
Hello. Another amplifier is not necessary, you can simply run the TMS69BL14 in parallel on the rear channels with the current TMS65 speakers in the tour pak. Inside the RFK-HD14 wiring kit box there were two black y-adapters, just connect one of those to the rear output and connect both sets of speakers to that.
Old Aug 11, 2020 | 02:13 PM
TexasMotorcycleRider's Avatar
How does that break out in the area of power? Are you effectively getting 50watts per speaker with that setup?
Old Aug 12, 2020 | 09:43 AM
Rockford Fosgate
Former Sponsor
Yes, that would be 50 watts per speaker on the rear with 100 watts going to the front speakers.
Old Aug 13, 2020 | 08:08 AM
Thanks. After asking the question I used my brain and Google'd it.
Old Nov 30, 2022 | 08:30 PM
liljoea2002's Avatar
liljoea2002
Z
I was running 8 speakers on the 1 amp.
RG1
Audio Systems
Apr 9, 2020 09:49 PM
fro10987
Audio Systems
Jun 13, 2018 04:56 PM
howertonv
2014-2024 Touring Models
Jul 7, 2017 10:16 AM
GNR
Audio Systems
Jan 24, 2015 03:40 PM
Jonny Cannon
Aug 28, 2009 12:07 PM
