Rockford Fosgate Audio High performance motorcycle audio systems, purpose built for Harley-Davidson.
Bridging RF TM400X4ad in stereo
Old Dec 15, 2023 | 11:32 AM
68_340_Cuda's Avatar
68_340_Cuda
Default Bridging RF TM400X4ad in stereo
I bought a used RF 2 speaker & amp kit (HD14-tkit) and ran it last summer.
I just bought GZ yellow baskets and would like to run the amp bridged for 200 watts per channel. I have read I can get the radio flashed for 4 speaker output which would give me stereo sound. As it is now it is only set up as a 2 speaker system with a LOC but I will be getting rid of it and flashing the radio.
Does someone make an adapter or harness to connect my factory HU to the read 4 pin connector on my amp?
tia
Old Dec 18, 2023 | 03:02 PM
Rockford Fosgate's Avatar
Rockford Fosgate
Former Sponsor
Hello. There are no adapters, for stereo bridged operation here is what you need to do:
1: Feed the Front inputs on the amplifier a Left audio signal only
2: Feed the Rear inputs on the amplifier a Right audio signal only
3: Set the input switch to the 4-channel position on the amplifier
4: Run the Left speaker bridged to the L+ and R- connections on the Front amplifier output
5: Run the Right speaker bridged to the L+ and R- connections on the Rear amplifier output
Note: Make sure the speakers are 4 ohm or higher, when running bridged
Old Dec 18, 2023 | 05:58 PM
68_340_Cuda
Perfect, that’s exactly what I’ll do. Thanks
68_340_Cuda
Audio Systems
Dec 21, 2023 06:29 AM
MrMetro
J&M Motorcycle Audio
Aug 25, 2019 07:15 PM
HogglyWoggly
Audio Systems
Mar 31, 2019 07:54 PM
FX4
Audio Systems
Mar 14, 2019 07:32 PM
ZZZCICI
Audio Systems
Oct 8, 2012 09:31 AM
