Tie down locations
Old Jul 12, 2017 | 09:21 AM
Zapper110's Avatar
Zapper110
2nd Gear
Wink Tie down locations
How do I tie down my FLHTCU SE5 electra glide ultra classic. Where should I attach the straps?
Old Jul 12, 2017 | 09:22 AM
NORTY FLATZ's Avatar
NORTY FLATZ
For a bagger, I use "Canyon Dancers."
Old Jul 12, 2017 | 02:01 PM
whocares's Avatar
whocares
Harley parts and accessories book has the tiedown brackets for the front(14 and up).they mount in back of your lightbar brackets.you can also find them on ebay cheaper. Also,you use your existing acorn nuts instead of the supplied bolts.for the back,either crashbar or rim.
Old Jul 12, 2017 | 02:48 PM
Billman812's Avatar
Billman812
I do; for the front, 1 each side to for lowers at fender spacer and to crash bars below steering neck. At the rear either the bag support or pass foot bracket. All get quality straps with soft tie straps and at least one front set should be ratchet.
Old Jul 12, 2017 | 05:03 PM
xupd42bmg's Avatar
xupd42bmg
I wanna get the biker bar!! No straps!!!
Old Jul 18, 2017 | 05:27 AM
jc15025's Avatar
jc15025
Veteran: Coast Guard
I have a biker bar!
Old Jul 19, 2017 | 06:17 AM
patrick74's Avatar
patrick74
for the front strap right above where the fender meets the forks. It allows you to strap tight and not compress your suspension. For the back I run my strap through the rear wheel pulling backwards in opposite directions. This keeps the back end from moving side to side and also does not compress the suspension. This way the suspension moves freely and no blown seals
kevin_n's Avatar
kevin_n
For the front I run the straps around the frame and for the rear I bought these https://www.yelvingtonusa.com/produc...-down-brackets. I tie my wife's sg and my sg the same way. Took. A trip to Arkansas earlier this rear with no problem or movement of the bikes.
Old Jul 19, 2017 | 06:24 AM
Notgrownup's Avatar
Notgrownup
This is what I do and I also have permanent hook spots attached to the sides of the top of the forks as well...double redundancy, in the back I just use ratchet strap to keep the rear from going side to side...
Old Jul 19, 2017 | 09:05 AM
pomeara's Avatar
pomeara
Default Tie down location
I asked 3 different people at the HD dealer where to connect on the bike for Tie Downs and got 3 different answers..
I would prefer to connect where the fender meets the fork and avoid the suspension compressing but it seems like such a low center of gravity that the bike will wobble too much.
I havent heard any horror stories about doing it that way so I will give it a try
