Information screen
Old Aug 12, 2017 | 08:07 AM
Lmr's Avatar
Lmr
6th Gear
Default Information screen
Does anyone make a screen saver for our bikes?
Old Aug 12, 2017 | 10:03 PM
tatcarr's Avatar
tatcarr
harley has them
Old Aug 13, 2017 | 08:00 PM
CVO SG's Avatar
CVO SG
screen savor or screen protector?
Old Aug 13, 2017 | 08:07 PM
Lmr's Avatar
Lmr
6th Gear
Protector I guess . I would like something to keep from scratching the screen with my gloves or fingers.
Old Aug 13, 2017 | 08:21 PM
jeff53404's Avatar
jeff53404
The only time I touch the screen is when I clean it with a microfiber towel. I always use the soft keys and joysticks to navigate the menus.
I took the following from the latest pdf of the Boom manual (page 197).
https://www.harley-davidson.com/cont...Boom_OM_EN.pdf
Replaceable Screen Protector
Boom! Box 6.5GT radios have a replaceable screen protector. Keep the protector on the screen at all times. Damage to the screen due to use without the protector will not be covered under warranty. Remove and replace the protector if it becomes dull, scratched or worn.
Old Aug 14, 2017 | 05:10 PM
smitty901's Avatar
smitty901
Look at it it has one on it now. Look carefully in the corners you will see the cut outs.
Old Aug 17, 2017 | 07:24 AM
DRBUICK's Avatar
DRBUICK
mine has one from the factory
Old Aug 18, 2017 | 08:43 AM
BigBadAllis's Avatar
BigBadAllis
They come with a protector already on them
Old Aug 18, 2017 | 01:33 PM
dixonk's Avatar
dixonk
I have also heard you can’t use the screen without one as it will scratch the screen. The stock one works fine although I try to use handlebar and soft buttons as much as possible. Less to clean that way.
AKL1
Oct 4, 2023 01:08 PM
overthehill?
Aug 4, 2017 02:32 PM
strtarrow
Jan 1, 2010 08:02 AM
jasonyankees
Oct 13, 2009 12:15 PM
cHarley
Jan 31, 2009 04:21 PM
